APU Compiler License Expired
8,405 次查看
weilly_li
Hi, Guys
      My APU Compiler License has expired, so how do I get a new license ?
Thank you
8,205 次查看
mikedoidge
Hello [email protected],
I have updated the expiration date on your license. Please try to activate it again.
Mike
10 回复数
7,655 次查看
Sandhya
Hi, My APU Compiler license has expired. I am trying to install the APU compiler v1.0 b657 now.
Will you be able to update the expiration date? Thanks!
8,206 次查看
mikedoidge
Mike
8,131 次查看
weilly_li
Dear Mike,
         Thank your help for last time !
         Recently, I have a problom about APU b657 license , My Account can't get it....
         So, Can you tell me what to do next ?  thank you !!
8,205 次查看
6905324
Hi Mike,
I have the same question now.
My APU Complier license has also expired, could you update my expiration date?
8,205 次查看
mikedoidge
Hello [email protected]‌,
We have extended the expiration date of the entitlement for the product. Please try again now.
Mike
8,205 次查看
hc17
Hello, Mike.
It seems that my liscense for the APU Compiler has expired on July 24,2020. Could you please update the expiration date for me? Thank you very much.
Chao
8,205 次查看
mikedoidge
Hello Chao,
I have extended the entitlement for the APU Compiler. Please try to do this by going to the Help -> NXP Licenses menu in S32DS and then select the ‘APU Compiler’ license from the list. Click Open and then Refresh. If this doesn’t work, you may need to use the ‘Return license’ button and then ‘Activate’ and enter the activation code again.
Mike
6,491 次查看
Martin321
Hi mike
It seems that my APU Compiler license has expired.
I have installed S32DS 3.1 and I am installing S32DS Extensions and Update, Vision extension package for S32V2xx 1.0.0.
It needs APU Compiler Software Activation Code. But all the APU Compiler licenses have expired(https://nxp.flexnetoperations.com/control/frse/dload_serialNum?item_key=12144337&plne=712807&certNum...)
Could you please update the license for me? Thank you very much.
@mikedoidge
@jorge_plascencia
6,481 次查看
mikedoidge
Hello @Martin321,
I have extended your APU Compiler License entitlement expiration date to 2026. You should now be able to re-activate the license using current activation code.
Mike
8,205 次查看
weilly_li
I have see my license update expiration date.
thank you so much !!
By the way, Have any license problem can I email you?
