I'm using S32DS 3.4
I have download AN12218SW.zip and successfully import into the IDE
however, i'm not able to compile.
it's seems that i have "Orphaned configuration. ...."
i can change the toolchain to select right NXP GCC 9.2... but there is no rule to make the target.
With my env, i'm able to compile project for S32K116 and also the bootloader exemple project
do you have any idea?
thank in advance
