I'm using S32DS 3.4
I have download AN12218SW.zip and successfully import into the IDE
however, i'm not able to compile.
it's seems that i have "Orphaned configuration. ...."
i can change the toolchain to select right NXP GCC 9.2... but there is no rule to make the target.
With my env, i'm able to compile project for S32K116 and also the bootloader exemple project
do you have any idea?
thank in advance
解決済! 解決策の投稿を見る。
Hi Francois,
this SW was created in older version S32DS 2.0:
The easiest option is to install this older version.
Lukas
Hi. Thank you for your answer.
Is there any plan to port it on newer version or/and other S32K, like K116?
Again, thank you for your support.
I'm afraid the answer is no, currently there's no such plan.
Lukas
ok, understood.
Thank again for your answers
Regards.
Hi Francois,
Lukas
