Thanks for your reply !
1). For me,I do not install a previous version of S32DS. and I also attempt to try a new workspace,but it does not work.
2). I can not understand "indexer". I am a newer at S32DS. so I can not find the "indexer" which you mentioned, and I think that is the reson for the question. So,can you help me with the indexer?
3). I use the S32DS 2018.R1, and the VSDK is come from the S32DS's example. so the s32v234_sdk's version probably is V1.2.
4) I am using the Linux install for Vision 2018.R1. besides, my colleagues and I follow the same procedure. but I got the error.
Finaly,My Linux version is Ubuntu 18, is this the reson for my problem? thank you very much.Looking forward to your reply.
