undefined reference to `g_pin_mux_InitConfigArr'
已解决
跳至解决方案
3,118 次查看
feng_ang
I made an error when compiling this file. I still made an error after updating the patch of version 14
1 解答
3,092 次查看
lukaszadrapa
Hi @feng_ang
did you generate the code before compilation?
Or select in main menu Project -> Generate Processor Expert Code.
This is usually the source of similar errors.
Lukas
在原帖中查看解决方案
2 回复数
3,093 次查看
lukaszadrapa
Hi @feng_ang
Lukas
3,085 次查看
feng_ang
Thank you. I have solved this problem.
