undefined reference to `g_pin_mux_InitConfigArr'
3,141件の閲覧回数
feng_ang
I made an error when compiling this file. I still made an error after updating the patch of version 14
3,115件の閲覧回数
lukaszadrapa
Hi @feng_ang
did you generate the code before compilation?
Or select in main menu Project -> Generate Processor Expert Code.
This is usually the source of similar errors.
Lukas
3,116件の閲覧回数
lukaszadrapa
Hi @feng_ang
Lukas
3,108件の閲覧回数
feng_ang
Thank you. I have solved this problem.
