s32k144 sCST
s32k144 sCST
veerajuvh619
Hi sir,
I am using s32k144 controller for that i am getting errors as
1. undefined reference to m4_scst_execute_core_tests
2. undefined reference to m4_scst_accumulated_signature
3. undefined reference to m4_scst_last_executed_test_number
how to solve this errors.
i also attached linker file also.
please provide documents related to sCST of s32k144.
Please provide the solution.
Veeraju V Hallikeri
Labels (2)
lukaszadrapa
When you added SCST component, did you click on Generate Processor Expert Code?
Can you confirm the library is linked like this?
If this doesn't help, could you share your project?
Lukas
veerajuvh619
Hi sir
I didn't found "lib_m4scst.a" in properties of my project.
that means library is not included but i clicked on Generate Processor Expert Code.
How to add lib_m4scst.a file?
Veeraju V Hallikeri
lukaszadrapa
is "scst1.h" included in that *.c file?
Lukas
veerajuvh619
Hi sir,
Yes, I included "scst1.h" file.
Veeraju V Hallikeri
lukaszadrapa
Lukas
gururajtalewad
I need S32K144 sCST library file. can you please share it to. [email protected]
