s32ds 3.5 license activation failed
1,375 次查看
Nitrogen8212
Hi NXP team,
s32ds 3.5 for windows system.
I installed it before, but then uninstalled it, and now I want to install it again, but it failed during the certificate activation process. I tried ONLINE and OFFLINE two ways, but both failed.
After selecting the 'online' method, the following information is displayed:
"Error sending an activation request to a remote activation server and processing the resulting response. The quantity specified exceeds maximum quantity allowed(0).(FNP error 0)"
The offline mode is also referred to the previous installation wizard operation, first upload the 'request.xml' file, obtain the 'activation.xml' file, and then the following picture is displayed:
"Invalid offline response, Response Type FAILURE"
And I try it many times, it's the same, so could you guide me on this question. thank you very much.
536 次查看
Allen_Cheng
I met the same issue.
Are there licenses available?
Thanks.
1,329 次查看
Nitrogen8212
It's successful now, thank you very much!
1,349 次查看
jiri_kral
number of available licenses has been extended. Please try to activate your S32DS again.
