Install S32 design studio, Error writing LaunchAnywhere components (Access Denied)
ソリューションへジャンプ
21,416件の閲覧回数
tommysvensson
I cant install S32 Design Studio for ARM v1.2  on Windows 7.
There is a error entry in the installation log:
Install Uninstaller: S32 Design Studio for ARM v1.2(Install All Uninstaller Components)
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
I have tired to run the installation as a normal user as well as administrator (Right click -> Run as Administrator). But installation still fails.
Is there a solution for this?
BRs
Tommy
Original Attachment has been moved to: S32_Design_Studio_for_ARM_v1.2_Install_09_02_2016_11_30_33.log.zip
18,990件の閲覧回数
tommysvensson
Finally managed to install S32  DS.
Had a look at the activation key in the webportal, and noticed that it was different from the one I gotten in the email.
The activation key from the webportal worked.
I guess that "Error writing LaunchAnywhere components (Access Denied)” means that the entered activation key is invalid...
Maybe the you(NXP) can improve the installation and give proper error messages and feedback to the users?
11 返答(返信)
14,533件の閲覧回数
lifepaper_cn
Hi I slove same problem in this way
1.search vcredist_x86.exe by everything software, then find it at C:\ProgramData\Package Cache\{f65db027-aff3-4070-886a-0d87064aabb1}\vcredist_x86.exe
2.delete it and re-install vcredist_x86.exe, it alert that have no permission to write C:\Windows\SysWOW64\msvcp120.dll
3.use this script to get the premission of SysWOW64 directory
https://blog.csdn.net/qq_25421741/article/details/115941861
4.re-install vcredist_x86.exe done, then install s32ds done
11,239件の閲覧回数
lifepaper_cn
Cause this problem again after move my disk to VM, I solved through this way(clear and offline active license)
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/S32-Design-Studio-Offline-activation-i...
18,990件の閲覧回数
xiehao5
Hi Tommy,
Please check the windows service "Server" status.
Installanywhere relies on the service.
Make sure the "Server" service is enabled and running.
Then retry the installation.
18,990件の閲覧回数
james4
windows service "Server"   is which serivce?The whole name of "server" is?
18,990件の閲覧回数
stanish
Tommy,
Just one more comment: I suspect you might swap Activation ID for S32DS Power and S32DS for ARM. This won't work. Each product requires its own Activation ID.
Stan
18,990件の閲覧回数
stanish
Hello Tommy,
Glad you are up and running - thanks for sharing the solution.
We recently made some changes to S32DS installer to be able to distinguish between Activation issues and the other installation issues.
Thanks!
Stan
18,991件の閲覧回数
tommysvensson
15,888件の閲覧回数
onestar
I got the same error! But in the installing process, I haven't get the window to enter my activation key.
So what can I do to solve this problem?
12,500件の閲覧回数
oguzkaganozt
There is no straight forward explanation of the error codes. Bad installation design unfortunately..
18,990件の閲覧回数
stanish
Hi Tommy,
Thanks for your report and apologize about the inconveniences.
I've checked the activation requests on our licensing server side and there is no entry related to your activation ID.
This may indicate that either installation failed before you entered your Activation ID or  you cannot access our server form your PC to activate it online.
Could you possibly try to activate S32DS using an offline method?
Offline activation on S32
Have you installed Visual C++ Redistributable Packages?
Please let us know if it helps.
Thanks!
Stan
18,980件の閲覧回数
tommysvensson
Have tried both online and offline activation methods before, with failed/installation rollback as result.
Just tried offline activation again, but installation still fails with
“Install Uninstaller: S32 Design Studio for ARM v1.2(Install All Uninstaller Components)
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)”
Have installed Visual C++ Redistributable Packages.
BRs
Tommy
