rolling back while installing s32ds 3.5
3,362件の閲覧回数
Harper
installation log is attached
4 返答(返信)
3,311件の閲覧回数
Julián_AragónM
Hi @Harper,
You can find in the first warning for the installation the following line:
"Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)"
Please confirm you are running the installer as an administrator.
Julián
3,299件の閲覧回数
Harper
Hi, @Julián_AragónM
I hava switched to the Administrator account. But it stiill rolled back.
Here is the newest log.
3,294件の閲覧回数
Julián_AragónM
Hi @Harper,
Please try out the solution shared in this community post: Solved: Re: S32DS for Arm v2.2 Installation is not Starting (Windows 11) - NXP Community
Also, select the option 'Windows 7 compatibility mode' on the file properties for the install file.
Julián
3,302件の閲覧回数
Harper
Hi  @Julián_AragónM
Thank you for your support. I'll try it.
