S32K3 IO Set Switch from Output to HighZ State
huangqiang11
S32K344 platform,PE0 Used to Feed an external watchdog,So I used the LLD Gpraphical Configuration to Configue the IO to gpio with Direction setted Output, But when the System goes to DeepSleep mode,the
watchdog needed to stop,So I need to Confige the IO to HighZ State. I need the IO Configuration to switch between Output and HighZ freely. But i cant find the Interface Function in the Code System supplied.
Robin_Shen
Read the chapter 7. Pad keeping in Standby mode of S32K3xx Low Power Management.pdf.
Hope it helps.
Due to limited resources, we are currently unable to support customers writing from generic email accounts such as gmail.com or qq.com or similar. Please ensure that you use your company email address when communicating with NXP so that we can prioritize your question accordingly. Thank you for your understanding.
Robin
