make: *** No rule to make target '
1,441 次查看
setsail
One month ago this project can be build.
But now after I imported the same project and build again  it reminds me that:
make: *** No rule to make target 'D:/WorkSpace/workspaceS32DS.Power.2017.R1/J8_B_V11/Project_Settings/Linker_Files/MPC5744P_flash.ld', needed by 'J8_B_V11.elf'. Stop.
1,341 次查看
jiri_kral
did you imported the project into the same S32DS version or into newer one? Is the MPC5744P_flash.ld file present in  Project_Settings/Linker_Files/ folder?
