hello
I'm having a problem importing projectinfo.xml file into S32 Design Studio.
In the projectinfo.xml file, I tried to use libraries with the settings as showed in the following picture.
The library file is mpc.a.
But after importing xml file , all configurations works but the library's configuration.
So I have to mannually add the library's name in order to compile the project successfully.
I have also tried to export the projectinfo.xml from an existing project with the right library settings.
But there is no "-l:mpc.a" in the exported XML file.
Is there anything wrong with my XML file?
Best regards!
Laura
