TRK KEA64 with external clock
1,318 次查看
hanisamara
i want to use the external clock on the TRK KEA64 board (FEE mode), but the software hangs on this loop:
while(!(OSC_CR & OSC_CR_OSCINIT_MASK));
i have the revision B and D Boards and i get the same result on both!
the oscillator is built on both boards but it seems like there is no clock?
i am using S32 DS and the file ics.c from the SDK.
i there any thing i miss to set/enable?
thanks in advance,
Hani
标签 (1)
标记 (3)
0 回复数
