how to set the float to single while compiling a S32DS for S32 project.
1,526 次查看
steven_zhang
Contributor V
my costumer genearted source code with matlab , the GCC compiles the float point constant as double. they wants the gcc compile the float point constants as single .i  chose the single precision contants as blew ,it desn‘t work,can anyone give me any suggestion for it.
1,501 次查看
jiri_kral
what's the target MCU and how are the float constant defined - it is something like const float f1=1.123456?
1,412 次查看
steven_zhang
Contributor V
 reason found. the thrid souce code generator difined the parameter for the function as double.
