how to add a macro function in symbols with S21DS?
1,692 次查看
JhonYF
As below,I want add a macro function named "Error_Handler()", the value is aseembly code,but it can not work and result the IDE report an error"expected string literal before 'BKPT",I don not konw what to do next , hope for help  ,thanks!
“Error_Handler()” is the macro function“Error_Handler()” is the macro function
标记 (1)
1,663 次查看
VaneB
Hi @JhonYF
I tried to reproduce your issue and got the same error as you. This error does not appear when you use the __asm__("BKPT") directly in the code, so it looks like the problem is macro.
Please refer to the community post below, which provides recommendations that will be useful for you.
Using Assembler Macros in C
B.R.
VaneB
1,599 次查看
JhonYF
@VaneB thanks for reply,but I still can not make it
1,641 次查看
JhonYF
Thanks for reply,but I still didn't make it
