MPC5777M GTM code compile problem
underdangerous
Hi:
I tried using the GTM configuration tool to create a simple project that utilizes GTM to generate PWM waveforms, but when I used the HighTec compiler to make the project, I encountered the following problem:
E:\Freescale\GTM Configuration Tool\examples_5777M/bin/main.c:52:error: relocation truncated to fit: R_PPC_VLE_REL24 against symbol `MC_MODE_INIT' defined in .mc_mode_init section in bin/mcu_init.o
I don't know how to solve it, I hope someone can help me!
jiri_kral
I found some suggestions on internet like https://community.st.com/t5/missing-questionpost/relocation-truncated-to-fit-r-ppc-vle-rel24-when-pl... - but it is related to gcc.
Try to contact HighTec compiler support.
