how S32 with PowerPC to generate library file(*.a file)
2,232 次查看
翔刘11
how S32 with PowerPC to generate library file(*.a file) ?
标记 (3)
1,989 次查看
stanish
I assume you want to build the library from S32DS IDE.
The New project wizard allows you to chose between application or library:
Hope it helps.
Stan
1,989 次查看
翔刘11
@Stanislav Sliva 员工  Thank you for your reply ,You are the best
1,990 次查看
stanish
Hope it helps.
Stan
