how S32 with PowerPC to generate library file(*.a file) ?
解決済! 解決策の投稿を見る。
I assume you want to build the library from S32DS IDE.
The New project wizard allows you to chose between application or library:
Hope it helps.
Stan
@Stanislav Sliva Thank you for your reply ,You are the best
