Vision Extension package for S32DS 3.2v
Prathiksha
Hi, I am trying to use Design Studio 3.2v and I notice that there is no vision extension package for this version available. Can I please know where I can find this ?
alejandro_e
Hello @Prathiksha,
Let me contact the team responsible for the software and I will let you know.
Thanks for your patience.
Prathiksha
Thank you! Can I also please know what versions of Design Studio are compatible with VSDK 1.5.4v ?
alejandro_e
Hello @Prathiksha,
I was not able to find version 1.5.4, however if you already downloaded and installed it you can check the release notes, for example in version 1.5.2 you can find it in C:\NXP\VisionSDK_S32V2_RTM_1_5_2\s32v234_sdk\ReleaseNotes.txt, in that file you can search for 'Design Studio', for instance in version 1.5.2, the recommended version is S32 Design Studio for Vision 2018.R1.
Please let me know if you have problems locating the file.
Prathiksha
Thanks for getting back on this. I did go through the release notes but I could not find the design studio version on the release notes. Could you verify it for me please if possible ?
alejandro_e
Hello @Prathiksha,
As I mentioned it seems the installer for version 1.5.4 is no longer available, if you still have it, can you open a private support ticket and share the file with me?
Please add the link to this post and/or my name to the description of the ticket so we can ensure I keep helping you with this topic.
Thanks!
alejandro_e
Hello @Prathiksha,
I have received a solution to original question, sorry for the late reply. Please follow these steps:
- Open S32DS 3.2, click on Help, then on Install New Software...
- In the new window, select the S32 DS update site:
- This will give you an error, this is expected, now change the link from http://www.nxp.com/lgfiles/updates/Eclipse/S32DS_3.2 to https://www.nxp.com/lgfiles/updates/Eclipse/S32DS_3.2 (not the added s: in https). Now you will se the Vision Extension package:
I was able to install the package successfully following this steps, please let me know if you are able to follow them as well.
Thanks.
Prathiksha
I actually need to use 3.2 version specifically for some testing. Is there any way I can get the vision extension package specifically for this version?
alejandro_e
Hello @Prathiksha,
Thanks for reaching out to us. About your question, checking the S32V available software for S32DS I was only able to find the S32V Extension package as old as 3.3. Is it possible for you to use a newer version of S32DS?
Also, did you intend to publish this question in one of your companies private communities? if so let me know.
Thanks.
