ToolChain compatibility
1,258件の閲覧回数
WANGS
In the S32DS ,NXP GCC 10.2 for Arm 32-bit Bare-Metal  compatible with NXP GCC 9.2 for Arm 32-bit Bare-Metal ? Whether an MCAL created with a higher version can be ported to a lower version
1,210件の閲覧回数
jiri_kral
the gcc versions - in meaning the built product like library - aren't compatible. You need to use the right version gcc version or use only source code, not the libraries.
