SVN plug-in for S32DS?
3,484件の閲覧回数
gearhead1107
I'd like to be able to update/ lock/ commit to Subversion (SVN) using the S32DS IDE - ideally with a plug-in like Subversive for Eclipse.
However, because Subversive expects you have the Eclipse Marketplace Client (MPC), I'm having difficulty installing it.
What do you guys use for version control on S32 projects?
ラベル(2)
2 返答(返信)
3,067件の閲覧回数
jiri_kral
New S32DS are based on Eclipse Neon. You can get Eclipse version from Help -> About S32DS For ARM
You can install any official eclipse plugin - including SVN.
Hope it helps.
Jiri
3,067件の閲覧回数
arjunraveendran
I am using "S32 Design Studio for Power Architecture" v1.2 and Eclipse Marketplace is installed by default.
However, if not present and you would like to install it, check this stackoverflow solution.
How do I install Eclipse Marketplace in Eclipse Classic? - Stack Overflow
