SVN plug-in for S32DS?
3,506 次查看
gearhead1107
I'd like to be able to update/ lock/ commit to Subversion (SVN) using the S32DS IDE - ideally with a plug-in like Subversive for Eclipse.
However, because Subversive expects you have the Eclipse Marketplace Client (MPC), I'm having difficulty installing it.
What do you guys use for version control on S32 projects?
标签 (2)
3,089 次查看
jiri_kral
New S32DS are based on Eclipse Neon. You can get Eclipse version from Help -> About S32DS For ARM
You can install any official eclipse plugin - including SVN.
Hope it helps.
Jiri
3,089 次查看
arjunraveendran
I am using "S32 Design Studio for Power Architecture" v1.2 and Eclipse Marketplace is installed by default.
However, if not present and you would like to install it, check this stackoverflow solution.
How do I install Eclipse Marketplace in Eclipse Classic? - Stack Overflow
