SDK ver.3.0.0RTM Issue while compiling code make: CCARM: Comand not found
2,454 次查看
shudhamatinarha
I am using S32K146 SDK ver 3.0.0 RTM
Waiting for your prompt reply
标记 (3)
2,322 次查看
stanish
It seems the makefile refers to GHS toolchain.
If you intend to build the project under GHS toolchain please make sure GHS eclipse plugin and GHS toolchain itself (multi) is installed and configured correctly on your machine.
see e.g.
GHS Compiler error in S32DS
https://community.nxp.com/message/1110877
Hope it helps.
Stan
2,322 次查看
jiri_kral
what's you build toolchain?
Jiri
