Problem multi-core debugging project
1,672件の閲覧回数
baptiste_mendio
I would like to debug your sema42_multicore project (NXP example) but when I launch the debug, a problem appear: " the following elf file does not exists.." with the link of the file of the second core.
I have already tried the solutions on this forum, but it doesn't work.
I use S32 studio.Power.2.1 and USB P&E multilink.
Thank you for your help,
Baptiste
1,572件の閲覧回数
lukaszadrapa
how did you create the project? When I imported it to S32DS, it seemed to have some weird format.
I tried to create new project using "File -> New -> S32DS Project from Example" and this is working on my side. I can debug the project using PE probe.
Lukas
