S32K312 RTC ISSUE
S32K312 RTC ISSUE
3,433件の閲覧回数
subhani
Writing the time and are working fine.
while reading the time and date, year also changing like seconds from 1970 to whatever the value im giving in year variable.
If I am writing the year as 1970 and reading the time and date is fine the year is not changing in this case. But if i write other than 1970 it is starting to change.
I am attaching the screen recorded video and my project please provide solution as possible.
3 返答(返信)
2,891件の閲覧回数
subhani
can I get example project for RTC with API interrupt and alarm interrupt.
2,888件の閲覧回数
danielmartynek
3,415件の閲覧回数
danielmartynek
Hi @subhani,
The result_buf struct must not be read before the Rtc_Ip_GetTimeDate() function is complete, becasue result_buf->year is reset to 1970 every time the function called. The driver then calculates the correct year.
