S32K3 - libc_nano.a(lib_a-memset.o) uses variable-size enums yet the output is to use 32-bit enums
5,783 次查看
ndd922478
I am getting below warning, could anyone please help me to get it resolved.
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: warning: c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/lib/thumb/v7e-m+fp/hard\libc_nano.a(lib_a-memset.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
Thanks & regards
Namdev
5,709 次查看
ndd922478
got resolved with below change,
5,710 次查看
ndd922478
