S32K144EVB UART connection PUTTY generates error
1,189 次查看
Kapila
I am learning to connect S32K144EVB UART connection with putty terminal. I have used the exmple project. But not able to communicate. Pl see the attached  and help me solve.
Kanakaraju
1,153 次查看
lukaszadrapa
Hi @Kapila
are you sure it's COM1?
Please check the port in Device Manager:
Your configuration in PUTTY should meet this.
Lukas
