S32G SAF 1.0.1 example project
zeyu_yan
I can not find the example project in s32Ds below.
S32G_SAF_SBOOT_UM:
My S32DS:
SW I have installed in S32DS:
I have install the software as the release note lists:
SW32G2_S32DS_3.4.0_D2012.zip and RTD Update Site - SW32G2_RTD_4.4_2.0.0_HF02_DS_updatesite_D2106.zip
S32G_SAF_1.0.1_ReleaseNotes.txt
Daniel-Aguirre
I cannot find any S32G_SAF update site in our site. There is an S32G_SPD_"ver"_DS_updatesite.zip which contains the example you are looking for (where "ver" is the version needed for your setup).
This seems to be working for my installation setup.
Please, let us know if this information helps you or not.
