S32DSv2018.R1 and GHS bundle org.eclipse.cdt.debug.mi.core
2,550 次查看
ralfhain
I've installed S32DS current version and want to install also the GHS-plugin.
But I get a not satisfied dependency.
Does anybody know the address where I can download org.eclipse.cdt.debug.mi.core?
Or is this conbination not pssible?
Details:
C:\NXP\S32DS_ARM_v2018.R1
C:\ghs\comp_201516
Cannot complete the install because one or more required items could not be found.
Software being installed: Green Hills MULTI for Eclipse (ARM) 2.1.8 (ghs.multi.arm.feature.group 2.1.8)
Missing requirement: MULTI Plug-in 2.1.8 (ghs.launch.multi 2.1.8) requires 'bundle org.eclipse.cdt.debug.mi.core 0.0.0' but it could not be found
Cannot satisfy dependency:
From: Green Hills MULTI for Eclipse (ARM) 2.1.8 (ghs.multi.arm.feature.group 2.1.8)
To: ghs.launch.multi [2.1.8]
Update:
"C:\NXP\S32DS_ARM_v1.3\eclipse\plugins\org.eclipse.cdt.debug.mi.core_7.3.0.201502131403.jar"
Idea: Copy the .jar to C:\NXP\S32DS_ARM_v2018.R1\eclipse\plugins
(Would this be feasible or will I run into an other dependency?)
标记 (2)
2,169 次查看
mikedoidge
Hello ralfhain‌,
We are aware of the issues regarding the GHS plug-in. Much of it has to do with the change to Eclipse Neon. Unfortunately, we cannot recommend a solution for this. You will need to contact Green Hills for a solution. It is purely a GHS - Eclipse issue.
Hope it helps,
Mike
