S32DS3.4/3.5_Blue Screen Issue_FC
Fidel
Dears,
       Recently , I met an boring issue when using S32DS to develop S32K, when I compile the program , PC sometimes became blue screen , I tried the version 3.4 and 3.5, both  have the same issue , and it randomly happend, my colleages also install the same version with the same version of Windows OS and patchs. but it is ok on his PC, and fail on my PC, the issue picture as below , anyone can tell me what happened and how to resolve it? thanks a lot~
jiri_kral
it is probably some HW issue with your PC - bad memory? Or something else.
Jiri
Fidel
Is it possible that the S32DS software is not compatible with the Windows OS ?
jiri_kral
not, it is not possible. To be honest - this is the very first time when I saw BSOD in relation with S32DS. As you said - your colleague is not facing this issue with the same configuration.
Try to check your HW - the Memory/Clock settings in BIOS is the most common source of BSOD.
Fidel
OK , I will try that ,thanks  a lot~
