powerpc-eabivle-gcc.exe: error
zipeng2001
Use the S32S software to compile the life, the compilation is not approved, I do not know the reason, the trouble guidance, thank you1666435887328.png
zipeng2001
It has not been solved yet. The platform currently used is S32 Design Studio for Power Architecture Version 2.1. It is now that the program has no way to compile it through this platform.
jiri_kral
sorry for delay. Did you solve the issue?
If not, can you please share more details? It is an example project or your own one? What is your S32DS version?
