S32DS installation error
1,129 次查看
wergtw
1,059 次查看
robert2003b
Check for the installation log file, which is typically located at C:\NXP\S32DS.x.x\_S32 Design Studio for S32 Platform x.x_installation\. Reviewing the log file can provide insights into what might be causing the installation issue. Sometimes, firewall or antivirus software may block the installation or activation process. Consider temporarily disabling these or checking their logs to see if they’re interfering. Ensure you have administrator access on your PC. This doesn’t mean to execute the installer using the ‘Run As Administrator’ option, but rather to conduct the installation from a user account that is part of the administrative rights group.
