S32DS for ARM /bin/sh: ccarm: command not found
4,717 次查看
gáborszüts
after starting the compile session i got the following error on several files:
After that the build is terminating.
I am using GHS ARM Standalone Executable Toolchain
标记 (3)
3,937 次查看
stanish
Hi Gabor,
you probably observe this error.
In order to build GHS based project in S32DS you should setup the build variable S32DS_GHS_PATH.
Go to Window -> Preferences -> C/C++ -> Build -> Build Variables (Show system varaibles) and enter the ghs tools path.
Note:  If you switch your workspace to a new one - you should re-enter this path again.
Then you should be able to build GHS S32DS project:
Hope it helps!
Stan
