u-boot 'md' command memory Error
prashantsathe
After flashing the kernel image, memory values from certain locations are not as per the kernel image.
we are trying to read the memory by using u-boot "md" command.
is it because of 'md' or is the related to flash memory. any pointer would be helpful. As per my understanding it shouldn't be flashing ( obviously). as kernel is able to boot .
Tags (2)
