S32DS for ARM 2018R1 license expired
8,965 次查看
shinjihontani-b
Can anyone help me?
8,958 次查看
mikedoidge
I have extended your entitlement through 2025. Please refresh your license or re-activate your S32 Design Studio installation using the existing activation code.
Mike
21 回复数
3,794 次查看
sunyongHwang
My S32 Design Studio for ARM v2018 R1 License has already expired,could you help to extend it?Thanks!
Activation Code: 8238-B154-F160-0911
3,898 次查看
ll3
Please renew the activation for S32 Design Studio for ARM v2018
With activation code: 31B1-59DE-872C-A3DB
5,434 次查看
fengxiaohua
5,307 次查看
jiri_kral
your license has been extended.
5,446 次查看
windy
Please renew my license for S32DS for ARM 2018R1.
5,308 次查看
jiri_kral
6,663 次查看
flyingpig4945
Hi!
My license(Activated Code: DF30-5AE6-7E72-33E6) is expired today.
Can u help me to extend? Thanks.
6,640 次查看
Mehul_Patel_NXP
Hi, @flyingpig4945 ,
I have extended your license through end of December - 2027.
Please refresh the activation.
Thank you. Kind regards.
- Mehul
7,062 次查看
WeiXiangdadadadadad
Could you help me for the expired license?
7,011 次查看
Mehul_Patel_NXP
Hi, @WeiXiangdadadadadad ,
- Mehul
7,580 次查看
frankmuenzner7421
Hi ,
Im new at S32SD ARM2018 ide, i had installed this older Version because some examples didnt work with newer versions in combination with iseled library...
So i try to test it with described in doku, for this i need a activated License for S32DS ARM 2018.R1
I have activation code but online activation did'nt work.
Order Number : S32-DS-ARM_v2018_51443548
If someone can help me urgently - it wouold really helpful - as i need the task to finish right in time, or it will affect my job situation... which is in 36h..
Any help is would support me to take my job...
Best regard,
Frank
7,572 次查看
Mehul_Patel_NXP
Hi, @frankmuenzner7421 ,
Please can you share the activation code for the S32DS for ARM 2018R1.
We can renew license for you.
Thank you. Best regards.
- Mehul Patel
7,567 次查看
frankmuenzner7421
Order Number S32-DS-ARM_v2018_51443548
Purchase Order Number
Total Number of Licenses: 100
Activation Code F322-DC2A-66B5-FBA3
7,529 次查看
Mehul_Patel_NXP
As I see, your S32DS license has been already renewed.
Please let me know if you are facing any issue.
- Mehul Patel
8,579 次查看
tommy1231
I am having the same issue.  Can you extend mine as well?
7,912 次查看
zhaogang
7,813 次查看
Mehul_Patel_NXP
Hi, @zhaogang
I have extended your entitlement through 2027. Please refresh your license or re-activate your S32 Design Studio installation using the existing activation code.
Thank you & Best Regards,
- Mehul
8,577 次查看
mikedoidge
Hi @tommy1231,
Your S32DS for Arm 2018.R1 license is now extended. You will need to re-activate, use the same code as before.
Mike
8,959 次查看
mikedoidge
Mike
6,367 次查看
6T9
my license for S32DS for ARM 2018R1 (activation code 77CE-47FA-4998-4F00) and the SW32K1-ISELED-RTM expired.
Could you please extend the licenses?
Thomas
