S32DS for ARM 2018R1 license expired
shinjihontani-b
Can anyone help me?
mikedoidge
I have extended your entitlement through 2025. Please refresh your license or re-activate your S32 Design Studio installation using the existing activation code.
Mike
flyingpig4945
Hi!
My license(Activated Code: DF30-5AE6-7E72-33E6) is expired today.
Can u help me to extend? Thanks.
Mehul_Patel_NXP
Hi, @flyingpig4945 ,
I have extended your license through end of December - 2027.
Please refresh the activation.
Thank you. Kind regards.
- Mehul
WeiXiangdadadadadad
Could you help me for the expired license?
Mehul_Patel_NXP
Hi, @WeiXiangdadadadadad ,
- Mehul
frankmuenzner7421
Hi ,
Im new at S32SD ARM2018 ide, i had installed this older Version because some examples didnt work with newer versions in combination with iseled library...
So i try to test it with described in doku, for this i need a activated License for S32DS ARM 2018.R1
I have activation code but online activation did'nt work.
Order Number : S32-DS-ARM_v2018_51443548
If someone can help me urgently - it wouold really helpful - as i need the task to finish right in time, or it will affect my job situation... which is in 36h..
Any help is would support me to take my job...
Best regard,
Frank
Mehul_Patel_NXP
Hi, @frankmuenzner7421 ,
Please can you share the activation code for the S32DS for ARM 2018R1.
We can renew license for you.
Thank you. Best regards.
- Mehul Patel
frankmuenzner7421
S32 Design Studio for ARM v2018
Order Number S32-DS-ARM_v2018_51443548
Purchase Order Number
Total Number of Licenses: 100
Activation Code F322-DC2A-66B5-FBA3
Mehul_Patel_NXP
As I see, your S32DS license has been already renewed.
Please let me know if you are facing any issue.
- Mehul Patel
tommy1231
I am having the same issue.  Can you extend mine as well?
zhaogang
Mehul_Patel_NXP
Hi, @zhaogang
I have extended your entitlement through 2027. Please refresh your license or re-activate your S32 Design Studio installation using the existing activation code.
Thank you & Best Regards,
- Mehul
mikedoidge
Hi @tommy1231,
Your S32DS for Arm 2018.R1 license is now extended. You will need to re-activate, use the same code as before.
Mike
mikedoidge
Mike
6T9
my license for S32DS for ARM 2018R1 (activation code 77CE-47FA-4998-4F00) and the SW32K1-ISELED-RTM expired.
Could you please extend the licenses?
Thomas
Mehul_Patel_NXP
Hi, @6T9 ,
Please renew the activation for S32 Design Studio for ARM v2018
With activation code: 21EE-10CB-FEBD-FD28
Please let us know if you are facing issue while activation.
-Mehul Patel
