已解决! 转到解答。
Hi, @lizhichaosdut ,
Please can you follow the below troubleshooting guide for 2nd case (com.acresso.activation.handler.ServerException)
: https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/Troubleshooting-Activation-fails-with-...
Please try the solution steps and reply us back if the solution worked.
Thank you. Best regards,
- Mehul Patel
As I am checking your activation request it is unable to get the unique machine number which should be attached to the PC.
it seems either you are using non-persistent virtual machine, if it is not the case, if may be the issue with flexnet publisher version is different or creating some issue, while you are migrating to the new PC. You can check the below troubleshooting guide in the case:
Please let us know if the any update on the issue.
Thank you. Kind regards.
- Mehul Patel
- Mehul Patel
Is this issue is resolved, please let us know the issue still persists.
Thank you. Kind regard.
- Mehul Patel
