S32DS IAR plug in error
rajesh057
Hi ,
I am using Latest version of S32K design studio for S32k144 microcontroller ,as per my requirement I need to use IAR compiler to compile code .I have installed IAR plug in to S32DS I can able to install successfully .but I need to compile with IAR compiler version 7.0 when I am selecting 7.0 I am getting following error .
please help me out from this problem .
Labels (2)
mikedoidge
The IAR Eclipse plug-in comes from IAR. You will need to contact IAR regarding this issue.
Mike
