S32DS Flash memory with MPC5744P
ivanmandic
I am trying to access flash memory to store data on it, but every time i reprogram the controller for example the medium flash memory blocks are erased. I found that u can set flash memory locations you want to preserve under debugger configuration in advanced options, but it doesn't do anything. And i have found nothing on web about the freescale_mpc5744p_1x32x616k_cflash.pcp they use for it. Is there any way to change it manually or in configurations?
Ivan Mandić
