S32DS Fails to Install
30,625 次查看
pmz1
Is there a problem with the Offline activation of S32DS? I have created the request.xml using the activation code provided by Software & Support : Licensing. When using the activation.xml file returned by Software & Support I get an Invalid Offline Response. The installer then roll back the installation.
Original Attachment has been moved to: S32_Design_Studio_for_ARM_v1.2_Install_07_21_2016_07_39_18_2.log.zip
26 回复数
6,078 次查看
pmz1
Hello Tomas,
I have tried both of the request files provided using offline activation. The first one (request1.xml) fails with invalid offline response. The second one fails with a different error.
I have included both log files.
Paul Zak
6,078 次查看
pmz1
Hello Tomas,
I assume you want me to try these request files using online activation. I will bring my laptop home tonight and try them.
Paul Zak
6,078 次查看
pmz1
Hello Stan,
I have tried the online activation from home and the installation fails. I get the following dialog.
The error log shows the same failure as with the offline activation.
Install Uninstaller: S32 Design Studio for ARM v1.2(Install All Uninstaller Components)
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Is there anything else you can suggest?
Paul Zak
6,078 次查看
martin_kovar
this error "Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)" could be caused by Java system path.
Look at the following threads, maybe it could help you a little bit.
S32 install on win7 - problem?
How to uninstall S32DS for ARM v1.1
Martin
6,078 次查看
pmz1
Hello Stan,
I have been unable to try online activation with the new activation code: 37D6-B186-B306-B6AA. I have to take my laptop to a different network since our work network is too restrictive. I will bring my laptop home tonight and try. I will email you with results tomorrow.
Paul Zak
6,078 次查看
allen_willson
Be sure to have Admin privileges during installation. On some systems the folders seem to be not writable to store license activation keys and temp files.  Recently at my customer, he had to not only run the installation with Admin privileges, but had to actually login as the Administrator.
On my own NXP laptop, I have to run as Admin in order for Processor Expert to generate code.
