S32 design studio, offline activation problem
4,656 次查看
alikozan
Hello
I'm trying to activate "S32 design studio" on my workstation with offline activation method. Although I've found the Software Licensing and Support tab, I can not find how to manage offline activation job from here. The screen I had is this:
How can i use the "request.xml" that i've given by the installer from here?
Thanks in advance
Ali
4,298 次查看
alikozan
Hello again
Solved it. It was because of downloading software while not logged in, so the product was not registered. I started a download session after logging in, and the product has been registered. Just after that, I've been able to activate the product by the way you offered. Anyway, thanks :smileyhappy:
Best Regards
Ali
4,298 次查看
stanish
hello Ali,
Please have a look here: Offline activation on S32‌
If you get "Invalid offline response, ResponseType" please check the fix here:  https://community.nxp.com/docs/DOC-334344
hope it helps.
Stan
4,299 次查看
alikozan
Hello again
Best Regards
Ali
