S32 Studio
S32 Studio
2,518 次查看
chaotingwei
hello!
  Where can I find instructions document of compile and link prossor ?
 Where can I find the Link file specification ?
标记 (2)
2,367 次查看
jiri_kral
In S32DS are standard GNU tools - make, gcc, ld. Here is GNU linker script documentation -https://www.eecs.umich.edu/courses/eecs373/readings/Linker.pdf
Part of installation is also Getting started doc - located in [YOUR_INSTALL_PATH]\S32DS_ARM_v2018.R1\S32DS\help\pdf\
Jiri
2,367 次查看
chaotingwei
hello ,Jiri Kral
    thank you!
