S32 RTD AUTOSAR 4.4 version 3.0.2 installation fail
3,979 次查看
asap
hi there,
noticed the S32 DS 3.4 update 3 provided S32 RTD Autosar 4.4 version 3.0.2:
when I clicked install, it always break in the middle, showing same error as below:
any idea about this error?
Albert
3,875 次查看
mikedoidge
Hi Albert,
We have the solution. It appears it is an issue with the Eclipse cache relative to this RTD package. Please delete the following directories and try again. It should resolve this issue for you. It worked in my case.
<Install Dir>\S32DS.3.4\eclipse\p2\org.eclipse.equinox.p2.core\cache\
<Install Dir>\S32DS.3.4\eclipse\p2\org.eclipse.equinox.p2.repository\cache\
Please try it and let us know the result.
Mike
5 回复数
3,970 次查看
asap
attached the log
Albert
3,968 次查看
mikedoidge
Hi Albert,
I was able to reproduce the issue on my end. It appears to be a problem with the update server. I will report this to the responsible team. They should fix it by tomorrow.
Mike
3,885 次查看
asap
thank you mike, but so far the issue remains.
Albert
3,876 次查看
mikedoidge
Hi Albert,
Mike
3,972 次查看
mikedoidge
Hello Albert,
Could you check your workspace directory for a file named '.log'. It should be located like follows: "C:\Users\Public\workspaceS32DS.3.4\.metadata\.log". In place of public, it may be your user id.
If you could share this file, there should be some entries that provide more details on the issue.
Mike
