S32 Design Studio for Arm license problem
11,442 次查看
arkadyosh
S32 Design Studio for ARM
Activation Id: A4AB-341F-FFD6-5513
My license expired and I can't renew it, when I try to return it I get information "Returning this license is not allowed."
How to solve it?
Thanks.
标记 (3)
11,422 次查看
jiri_kral
I returned the license for you, please try the activation procedure again. If it fails, try to start new download (you can cancel it when started) and check if the activation key isn't different.
Jiri
17 回复数
9,595 次查看
ivankarezic
Hi, I want to install S32DS on my other computer as well but, as it seems, one can use only single license. Can you add additional slot or return existing so that I can proceed with installation on second machine.
Thank you in advance!
9,565 次查看
Mehul_Patel_NXP
Hi, @ivankarezic ,
The S32DS activation license can work for 100 installation instances. You should be able to use your existing license on the other machine, but if you are facing any issue, please can you share your activation code number, so that we can check if any issue.
Thank you. Best regards.
- Mehul Patel
9,522 次查看
ivankarezic
Hi @Mehul_Patel_NXP ,
Can you please provide some input on this one, thanks!
9,560 次查看
ivankarezic
Thank you for quick reply.
Here is the activation code:
6DD5-73FC-6F3E-DDF8
And this is the error I get when trying online activation
9,507 次查看
Mehul_Patel_NXP
Hi, @ivankarezic ,
Sorry, for missing your previous message.
I have increase license quantity for your activation. You can use that many instance of S32DS (on difference machine or same machine).
Please let us know if you are facing any further issue.
Thank you. Best regards,
-Mehul Patel
9,500 次查看
ivankarezic
@Mehul_Patel_NXP ,
Thanks for the help, installation now works as expected.
Appreciate the effort!
10,790 次查看
JSekinger
my S32 Design studio license is expired!
Need urgent help.
License Quantity:Fulfillment ID:Expiration Date:Product:Machine:Activation Code:
1
157906587
Jul 16, 2022
S32 Design Studio for ARM v2018 R1
31B0183D8F91C81588FA2D7DE8CC272C850D45A9
33AD-3B0E-5B9F-8555
10,792 次查看
JSekinger
my S32 Design studio license is also expired!
Need urgent help.
1
157906587
Jul 16, 2022
33AD-3B0E-5B9F-8555
11,043 次查看
jiri_kral
please try to activate your S32DS again.
Jiri
11,051 次查看
振兴
Hi:
My soft :S32 Design Studio for ARM  2018.R1
Now i have a same problem "The license expired and I can't renew it,"
Can you help me?please!
Thank you!
11,324 次查看
MarcinW
I have the same problem. I tried to use the activation code that is on my account, but nothing. I also used an offline routine with xml files, but that didn't help either. Please help.
FulfillmentID:
149206157
Activation Code
4D7E-E0D6-A702-23FE
11,432 次查看
jiri_kral
Hi Arkadiusz,
your license was expired - I extended it till Dec 31, 2025. Please try to activate your S32DS again with the same code.
Jiri
11,428 次查看
arkadyosh
Tkanks Jiri for your response,
Unfortunately I still cant activate IDE. I try online and offline method.
I attach image what happened when try to active.
When click 'No' license is still expired but when I press 'Yes' I get:
Any others suggestions?
11,423 次查看
jiri_kral
Jiri
6,021 次查看
ndw
Hello, I followed the instructions to delete and re-register the license, but the issue is still not resolved. My activation ID is 2E58-C292-E95A-F172.
11,071 次查看
tom_20xx
hello, I meet the same problem. my code is C553-F7D3-4E36-7B50 for S32 DS 3.4.0, can you help me ?
11,414 次查看
arkadyosh
Thank You very much, this resolve the problem.
Arkadyosh
