S32 Design Studio for ARM v2018 R1 Missing - 20230923
1,738 次查看
WeiXiangdadadadadad
How to extend?
Why are there 3 records?  Is it because the license used by 3 PCs?
How to know which one my computer is using?
1,680 次查看
Mehul_Patel_NXP
Hi, @WeiXiangdadadadadad ,
As I see your were using the same activation code for 3 different Machines, may be that created issue activation.
I have returned the license for each, and license has been extended thought 2027, please can you check whether it works or not.
Please let me know if you are still facing the issue.
Thank you. Best regards.
- Mehul Patel
1,646 次查看
roilop
Hello
I have the same problem, the license I have is expired since last year and I have no way to activate S32 Design Studio 2018.R1.
How could I do to solve it?
1,681 次查看
Mehul_Patel_NXP
- Mehul Patel
