S32 Design Studio debug mpc5606b error issue
4,711件の閲覧回数
maoyuanluo
hi:
   when i create a mcu(mpc5606b) project and i want to debug, the error info as follow:
when i choose the yes and choose Retry, the Console info as follow:
Connection from "127.0.0.1" via 127.0.0.1
Error : Error in ONCE status register during instruction execution.
Copyright 2017 P&E Microcomputer Systems,Inc.
Command Line :D:\NXP\S32DS_Power_v2017.R1\eclipse\plugins\com.pemicro.debug.gdbjtag.ppc_1.7.2.201709281658\win32\pegdbserver_power_console -device=MPC5606B -startserver -singlesession -serverport=7224 -gdbmiport=6224 -interface=USBMULTILINK -speed=5000 -?
CMD>RE
Initializing.
SPC560xxx Device detected.
Target has been RESET and is active.
CMD>CM D:\NXP\S32DS_Power_v2017.R1\eclipse\plugins\com.pemicro.debug.gdbjtag.ppc_1.7.2.201709281658\win32\gdi\P&E\nxp_mpc5606b_1x32x256k_cflash.pcp
Initializing.
Unknown Device detected.
Not able to access processor. Try a software reset.
Error loading programming algorithm - load aborted.
Error occured during Flash programming.
Debugger retrying force to background mode.
How can i fix the error?
4,524件の閲覧回数
maoyuanluo
I fix it by D:\NXP\S32DS_Power_v2017.R1\eclipse\plugins\com.pemicro.debug.gdbjtag.ppc_1.7.2.201709281658\win32\gdi\P&E\s32e200_mpc560xx.mac reset scriptfile. Thank you!
3 返答(返信)
4,525件の閲覧回数
maoyuanluo
4,524件の閲覧回数
Yunhe
Hello, I found the file, could you tell me how to use this file to fix the error, thank you
4,204件の閲覧回数
bingwang312
i found it too, and in debug configuration-> advance button, it has alternative script selection to give us a chance to do some cleaning after flashing memory, i found /chose that s32e200_mpc574xp.mac and run debug again, errors are still there, no difference.
if you open that .mac script file using notepad.txt, you can see the commands seem only for cleaning some memory space, nothing special.
I tried older project' .elf programmed with register values( which did not use SDK) ,  flashed the old .elf code into my DEVKIT MPC5744P board, it worked well, it means my devkit board is ok. I am pretty sure there are some bugs in latest version of S32DS PA v2.1 compiler/debugger, though I have updated everything to the lastest versions.
I am looking forward to next version of S32DS PA, hopefully they can work it out.
