S32 DS KEA-128 Open Project
5,606件の閲覧回数
ugurozkan52
Hi everyone,
I have a TRK-KEA128 i am using S32DS for TRK programing but S32 DS is not found device how can i solve ? Regards
8 返答(返信)
4,590件の閲覧回数
ugurozkan52
Hi Yunus,
I am sorry for I couldn't answer your question.
I couldn't solve problem. I desided using Code Warrior and Kinetis Design Studio.
Uğur
4,590件の閲覧回数
vigneshbalaji
Senior Contributor I
    what is the advantage of using S32 over KDS or codeWarrior?
4,590件の閲覧回数
yunus_ozdemir
Did you solve the problem Uğur? Unfortunately, I got same problem and still trying to solve.
Yunus.
4,590件の閲覧回数
ugurozkan52
I using Windows 10 and have java version 8 update 92
I will try me too
Thanks for your concern,
Ugur
issue
4,590件の閲覧回数
ugurozkan52
Alice_Yang Thank you for your suggestion. I will try Kinetis Desing Studio IDE.
Martin Kovar ​I have S32 Design Studio for ARM Version: 1.2 but when I created new project I didn't see your table. I activeted from site of nxp. Did you create kinetis-sdk or any patchs also did you update anything.
Thanks for your concern.
4,590件の閲覧回数
martin_kovar
I uninstalled all versions of S32DS for ARM and installed just version 1.2 and I cannot still reproduce your problem. I have only installation of S32 without any updates, patches or SDK.
Could you please tell me, which OS you use? Also please write me, what is your Java version. I will try to find you the issue.
Martin
4,590件の閲覧回数
martin_kovar
could you please specify, which version of S32DS you use? I have installed S32DS version 1.2 and when I create new project, I see this table:
Have you activate your installation?
Martin
4,590件の閲覧回数
Hello ,
You can use the KDS IDE, it is free and it support this chip,
and it is easy to used.
you can download it at here :
Kinetis Design Studio Integrated Development Enviro|NXP
Hope it helps
Alice
