S32 DS Compiler/Assembler/Linker version
2,292 次查看
leekate-b45752
Hello Team,
The customer requested the Compiler/Assembler/Linker version of SW tool for S32K144.
Where can I check these versions in S32 DS v1.2?
According to the '2016_04_18_S32K_Complier_Version.txt', GCC is 4.9.3 20150529, but it is 8.6.0.201502131403 in S32 DS installation details, which version is correct?
Thank you.
Kate Lee
标签 (2)
标记 (3)
1,939 次查看
stanish
Assembler and Linker version:
Stan
1,939 次查看
stanish
Hi Kate,
There is no compiler version visible in S32DS Installation details. It shows just version of an eclipse plug-in.
In order to get the version of gcc you should run "arm-none-eabi-gcc --version" from the command line:
Stan
1,939 次查看
leekate-b45752
Hi Stan,
Could you let me know how to check the version of assembler and linker also?
Thank you.
Kate Lee
