Register map for S32K148
5,017 次查看
miyazaki_0728_4
Is there a document including registers map of S32K148?
I found the data sheet, https://www.nxp.com/docs/en/data-sheet/S32K-DS.pdf . But, it doesn't have register map.
标记 (2)
4,827 次查看
jiri_kral
I'm afraid that there is no such document (registers map). In reference manual you can find memory map - https://www.nxp.com/docs/en/reference-manual/S32K-RM.pdf
All registers are described in modules (UART, GPIO...).
Jiri
4,828 次查看
jiri_kral
Jiri
4,487 次查看
Maijaaah
that link goes to "Page not found". Is that document still somewhere available? I can't find it.
4,827 次查看
miyazaki_0728_4
Hi Jiri
 This is what I want to have. Thanks!
Hideki
